Message 1 of 7
Heavy Hacking Attempts
Hello all,
Getting really heavy pounding on connections attempts, bascically brute force, 10,000+ in 3 hours, must be a bot/programme. Anything that can be changed, ie router identity for example?
BT Hub 6A
Thanks.
6 REPLIES 6
Message 2 of 7
Re: Heavy Hacking Attempts
You can try getting a different IP address, disconnect your hub from line for 10-15 minutes.
Message 3 of 7
Thanks for the tip, I pulled the BT line from the router overnight, but just started up again when I reconnected this morning.
Message 4 of 7
Nothing else you can do unfortunately.
Message 5 of 7
Thanks, guess I'll just hunker down!
Message 6 of 7
Unless you need it, turn off UPnP to be on the safe side.
Message 7 of 7
Thanks, assume UPnP needed for Playstation, Smart TV (Netflix etc)?
