Message 61 of 82
Re: Help! BT blocking a website i was building!
Ahh sorry.
Yes I can’t resolve that domain from our servers. We have not actively blocked it so I’ll investigate what’s going on.
Steve
Message 62 of 82
We’ve repropagated the domain now so should be good.
Steve
Message 63 of 82
Thanks Steve, this seems to have fixed it! Much appreciated!
Message 64 of 82
Hi Steve,
We have a similar issue with our app (app.wavecnct.com). I've contacted the BT safer browsing email multiple times to no response. It's seems all of our customer using BT Group network cannot see our website
Message 65 of 82
Hi Steve,
We are having the same issue when accessing images
for some reason, all our customers via BT and EE are not able to see images in our site.
our clients are not able to reach this. Can you please help?
Thanks,
Luis
[Mod edit: links removed]
Message 66 of 82
@luisdinis
Your link works fine. You will need to remove the links. It is not permitted on this site to post links to e-commerce sites.
Message 67 of 82
Thanks!
I will edit the message to remove it.
We have multiple customers complaining. When accessing from BT or EE broadband they are able to reach the site but not see any images.
Are you able to see any pictures via any of these ISP?
Message 68 of 82
Yes.
Check with your clients to see if they have parental controls and what browser they are using.  It is obviously not a universal problem.
Message 69 of 82
We did. We followed all the procedures with customers recomended in BT Help
We were able to replicate the issue: see below if we use a diferent DNS vs the DNS from BT:
2 days of customers without service due to this.
user@user-desktop:~$ curl
81.139.39.228
user@user-desktop:~$ nslookup cdn-images.farfetch-contents.com 62.6.40.178
Server:		62.6.40.178
Address:	62.6.40.178#53
** server can't find cdn-images.farfetch-contents.com: NXDOMAIN
user@user-desktop:~$ nslookup cdn-images.farfetch-contents.com 1.1.1.1
Server:		1.1.1.1
Address:	1.1.1.1#53
Non-authoritative answer:
cdn-images.farfetch-contents.com	canonical name = ff-contents.cn.edgekey.net.
ff-contents.cn.edgekey.net	canonical name = ff-contents.cn.edgekey.net.globalredir.akadns88.net.
ff-contents.cn.edgekey.net.globalredir.akadns88.net	canonical name = e2866.dsca.akamaiedge.net.
Address: 23.214.208.111
Address: 2a02:26f0:fd00:588::b32
Address: 2a02:26f0:fd00:59c::b32
user@user-desktop:~$ nslookup cdn-images.farfetch-contents.com 8.8.8.8
Server:		8.8.8.8
Address:	8.8.8.8#53
Message 70 of 82
- BT DNS resolver: 62.6.40.178
- NSLookups showing the BT resolver is not being able to respond to the DNS query for the desired hostname:
Server:		62.6.40.178
Server:		1.1.1.1
Address:	1.1.1.1#53
- NSLookup showing Google and Cloudflare open DNS resolvers being able to respond:
Server:		1.1.1.1
Address:	1.1.1.1#53
Server:		8.8.8.8
Address:	8.8.8.8#53
We hope this information helps diagnose the root cause and resolve it as soon as possible.
