Message 1 of 6
How do I access posts in t/5Archived/staging/
There is reference to a good beginners guide to setting up a Smart Huib as a wifi extender here
https://community.bt.com/t5/Archive-Staging/BTHub6-Smart-Hub-As-WiFi-Extender-or-AP-Access-Point-amp...
When I try to access it I get You do not have sufficient privileges for this resource or its parent to perform this action.
How can I access this post?
5 REPLIES 5
Message 2 of 6
Re: How do I access posts in t/5Archived/staging/
@rincewindwiz
You cannot access it because its been archived.
Message 3 of 6
Is there a way to access this archived page?
Message 4 of 6
Which part of ' you cannot access it' did you not understand?
Message 5 of 6
Thanks for your answer. But archived does not mean deleted. Archive means that it can be accessed in a way. Ex: sending an archived page via email or private message.
Message 6 of 6
The message actually states
"You do not have sufficient privileges for this resource or its parent to perform this action".
Unless you become a BT employee and then get a position as a forum moderator, you will never gain those privileges.
