Message 1 of 2
I have a BT smart hub type A, and I would like to connect it to my sky hub, so it acts as a second network, while running of of sky's Lan. I don't have any dsl connections, and can't figure out how to get this to work.
1 REPLY 1
Message 2 of 2
Re: BT Hub
Simply give it an address outside of the DHCP range of the Sky hub, set the IP address of the Sky hub as Gateway, turn off DHCP on the BT hub and connect LAN to LAN
