Message 2 of 3
How do I know if I have Whole home or whole home wifi6?
How do I know if I have the Whole Home Wifi standard or the Whole Home wifi6? Or the complete wifi?
What is the difference between the three?
Which one is included in the Halo Fibre packages?
I have black ones I got with my Halo 3plus package 4 years ago. I also need a guest network but I'm having trouble finding out how to do this.
If my discs aren't wifi6, can I get them and will they work with the Smart Hub 2?
2 REPLIES 2
Message 1 of 3
What is the difference between the two?
Anonymous
Not applicable
Message 3 of 3
Re: How do I know if I have Whole home or whole home wifi6?
Black discs are Complete Wifi & they neither support WiFi 6 or a guest network.
I believe the latest EE Smart Hub Plus is WiFi 6 & has it's own mesh system, but you'll probably need to move to EE  to get those. That opens a whole new can of worms. So purchasing your own mesh system is probably more economical. But then BT seem to be extremely reluctant to let anyone drop the Halo package to compensate for not using the BT discs.
