Message 1 of 5
How to get new equipment after returning
 Hi ,
As request of BT, I have plan to return my equipment (as I checked, Smart Hub2 should be returned)
After returning this equipment, how should I get new equipment ?
If you have answer, please help me.
Looking forward to hearing from you !!
4 REPLIES 4
Message 2 of 5
Re: How to get new equipment after returning
You only return equipment if 1) you are leaving BT or 2) It is old equipment that you no longer need or want or 3) BT have requested that you return the equipment for some reason which would be explained to you at the time of the request.
In all these instances why would you need or seek new equipment from BT.
If you are leaving BT to go to a new Broadband provider the new provider will supply you with the appropriate equipment for their service.
Message 3 of 5
The reason is that BT have requested to return the equipment (Smart Hub)
I don't leave BT and I want to use BT.
Therefore I would like to know how to get new equipment after returning.
Message 4 of 5
Why have you been asked to return it? Unless you have been sent a new hub there is no reason for BT to ask for anything to be returned.
Message 5 of 5
Do you have a landline phone and is it being changed to Digital Voice?
If it is you would need the Smarthub 2 which BT will send out to you however BT would have explained that to you when they asked for the Smarthub to be returned.
