Message 1 of 4
Router
Hi all
Currently in the process of moving home.  My current setup is a TP Link VR2800 modem/router connecting into my line of approximately 33mb speed
The new property will have 500mb speed and will therefore have an open reach modem. The question is, if I set the VR2800 into router mode, will it work ok? I won’t have a phone connected, so that won’t be an issue to me
If not, can anyone suggest something, I’d rather not use the standard BT delivered one
thanks
3 REPLIES 3
Message 2 of 4
Re: Router
You tplink should work without problem set to router mode
Message 3 of 4
Re: Router
Just connect the ONT (optical modem) to the WAN port of the TP Link.
Message 4 of 4
Re: Router
Thanks for the confirmation @licquorice & @imjolly
