Message 1 of 2
Hub Manager
Hi, When trying to set up access times for my son's Ipad I can't find his ipad within the app but i can see it via hub manager on my PC. i've tried searching for it via the IP address and MAC address but it's not there??? but it's a plain as day on the Hub Manager via PC but you can't change any of the setting via hub manager only with the app. how do i find this device via the app.
1 REPLY 1
Message 2 of 2
Re: Hub Manager
Depending on what version of iOS it's running, you won't find the MAC. MAC addresses were randomised from (if memory serves) v14 onwards, i.e. it uses a made up one. You may have to disable this if you want to use parental controls.
Private Address-MAC Randomisation (iOS14) Apple de... - BT Community
