Message 1 of 5
Hybrid connect device.
Hello again,
I have another question. Broadband is working fine, but amongst the upgrade package was sent an EE Hybrid Connect device.We live in a bungalow in South West Wales in quite a remote position. If I connect the  Hybrid Connect using ethernet port I have three red bars.If I plug Hybrid Connect paired with hub in the living room  I achieve 1blue bar sometimes three red. I'm not very technically minded, any tips that may improve the signal or is it just I live in a low signal area?as I said Broadband is working fine, just wondering if there is any way of improving signal,should we loose Broadband the conventional way.thanks in advance.
Richard
4 REPLIES 4
Message 2 of 5
Re: Hybrid connect device.
check strength of your EE mobile signal in your area/home and see if some parts of home get better mobile signal
Anonymous
Not applicable
Message 3 of 5
You could try purchasing some additional aerials & locating the device in the loft if there's power there. There are also external grade aerials you can fit, but you'd probably need advice from a local specialist as to whether it's worthwhile.
Message 4 of 5
Thank you for your advice
Message 5 of 5
Thankyou for your advice
