Message 1 of 5
I need QoS for gaming and have Smart Hub 2
The Smart Hub 2 doesn't have QoS. I don't really understand how to get QoS. Can I just buy a router that supports FTTP and has QoS? Or do I have to do more complicated things?
Thanks to anyone who tries to help.
I have the Fibre 500 but noticed a difference when it was only my computer connected testing the internet vs when more active devices were connected.
4 REPLIES 4
Message 2 of 5
Re: I need QoS for gaming and have Smart Hub 2
Any router with a WAN port and supports PPPoE (virtually all) will suffice. You don't need a modem/router, just a plain router.
However, if you have Digital Voice phone service, it will only work with the SH2.
Message 3 of 5
Do you have any recommendations?
Message 4 of 5
If you use your landline to make calls and have digital voice then you need to use the sh2
Message 5 of 5
Only you know what your budget and requirements are. Asus and TP Link models are popular.
