Message 1 of 11
IP camera causing Frustration!!
Hello All,
I am hoping for a simple answer or solution to why my IP camera no longer works as expected.
I have a Tenvis TH661 (Phone Galaxy S10/New Tennis App) which I use on BT broadband network for several years without issue. I can connect to the camera at home on both wifi and mobile data and more importantly when abroad (Europe) on both Wifi and mobile data. I am very happy with the camera for my needs.
Then, BT informed that digital voice was coming and I needed a new router ( BT Smart Hub) which I duly plugged in and connected all my devices to without issue. I connected my camera and it worked fine while as I was home. When I say fine I mean it connected on wifi but not as I realised later mobile data while at home.
In France, I could not connect to the camera via wifi or mobile data to the camera. On returning to the uk, using a friends wifi, I still could not connect to the camera even when I tried mobile data.
Once I arrived at home the camera worked perfectly with my phone app but not on mobile data. I now think my phone stopped working on mobile data when the router was upgraded.
So, before the BT router upgrade I could connect to my ip camera over any wifi network and mobile data anywhere in the world.
My question is, I assume the security, port forwarding and/or pinhole on the router settings need adjusting but I have no idea how to do this or perhaps something else is amiss.
Any help will be great and easy to follow instructions would be appreciated.
Navy
10 REPLIES 10
Message 2 of 11
Re: IP camera causing Frustration!!
Good afternoon @navy.
Welcome to the BT Community!
Just so I can be sure we've got the right idea of what's happening here, am I correct in thinking that this camera is permanently connected to your home WiFi, and in the past you could connect to this and view the feed from anywhere over both WiFi and data?
I can't say for sure which ports the camera itself will require, this will most likely be in the device guide for the camera itself.
You can find details on how to set this up via our help page here.
Peter
Message 3 of 11
Peter, thanks for replying
Yes, that is exactly right.
The moment BT sent me BT Smart Hub because of digital voice I could only connect to my ip camera over my home network and nowhere else Wifi or mobile data.
Thanks again
Message 4 of 11
Thanks @Navy1 😊
I'd definitely recommend checking out that article that I'd shared, but you may need to reach out to Tenvis for specific details on port settings.
There may be a simpler solution with this though, when you switched to you new hub, did you make sure that the camera had forgotten your previous one and set this up fresh?
It could be worth re-adding the camera to your network via its dedicated app, and ensuring any software linked with it is up to date too.
Peter
Message 5 of 11
Many thanks Peter,
I have been trying the link you sent but with no success.
I will contact Tenvis and see which port their IPcamera uses. So far from google 80,554,8001. I've tried all by creating a port forwarding rule but so far no luck.
Thanks for the advice and help.
Message 6 of 11
All you need to do is replicate whatever port forwarding and Dynamic DNS settings you had on your old hub on the new one.
How are you actually accessing the camera?
Does the camera upload images to a server and you access it via that or do you access it directly via your hub?
Message 7 of 11
Many thanks for responding.
Sadly my old hub was returned to BT as requested so I have no access to the old settings.
The images are viewed directly from the hub.
I'll try setting the camera up as a new camera and reset the hub.
Thanks again
Message 8 of 11
In that case, not only will you have to set up port forwarding to the camera's IP address, you will also have to configure the hub for the DDNS service you are using.
Message 9 of 11
Thanks for replying.
I am trying to understand the port forwarding which I think makes some sense now but the DDNS is something totally new to me.
Would you be kind enough to expand what I need to do to configure my BT Smart Hub to DDNS.
Many thanks
Message 10 of 11
To access your camera remotely you must have created an account with a DDNS service such as NoIP or DynDNS as your public IP address is dynamic and will change.
This service needs to be configured on your hub so that the service can track the changes to your IP address.
If you go to the hub manager > Advanced settings > Broadband > Dynamic DNS you can configure the hub with your account settings.
