Message 1 of 11
If BT really blocking traffin inbound towards my router?
Rhetoric question... any port forwarding I setup on my device doesn't work.
I have my own device that works find on Virgin Media, I just plug BT in and all of the sudden all the services I have on the router (VPN to mention one) are not reachable.
I have verified this in two ways:
 - https://canyouseeme.org
 - locally on my router using tcpdump. No even a SYN is received on the opened port.
Can anyone confirm this is wanted and expected behavior?
I'm still within the 14 days cooling off period so this is a decision making point for me.
Thanks!
10 REPLIES 10
Message 2 of 11
Re: If BT really blocking traffin inbound towards my router?
BT don't block traffic.
If you are running a VPN, your perceived public IP address won't be the public IP address of the hub.
Message 3 of 11
VPN inbound not outbound, also this VPN doesn't set the default gateway it's site-to-site.
As mentioned there is no SYN received on the device I'm using although connectivity outbound works.
I have just spoken to a tech support guy and he had a good point I'm going to test now:
- disable any filtering on the BT account interface and see if that help
I'll feedback soon.
Message 4 of 11
Nope. All the filters are off on my account and I can get no packet inbound.
Message 5 of 11
Can you confirm that your public IP address as shown at https://www.whatismyip.com/ is the same as that shown by the hub.
Message 6 of 11
109.148.166.253
Message 7 of 11
So ping works, but I couldn't establish any TCP/UDP from the Internet.
Message 8 of 11
I am testing with my own device behind the BT hub2 now using a DMZ config. Same result. Ping towards the public IP works but any other port for services I host on my router is just not reachable.
Message 9 of 11
I had a lengthy call with BT Tech support. It took a while to get through the right person but eventually I could have a proper tech conversation. Friendly and emphatic but after 60 min of attempts they lifted white flag as they have no idea on what's the root cause.
Message 10 of 11
@bellocarico wrote:
109.148.166.253
That doesn't actually answer my question. Are the 2 IPs the same?
