Message 1 of 3
Smart hub 2
Can anyone tell me if the smart hub 2 has wps and if so where I can find it.
2 REPLIES 2
Message 2 of 3
Re: Smart hub 2
With the front of the router facing you, it's an indented button on the rear left of the unit about half way up.  A short, positive press is all it should need.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 3
Re: Smart hub 2
Great, thanks for your help.
