Message 1 of 4
Important Message About My Account?
This pops up every time I try to connect to my WiFi, I’m so confused I can’t seem to find this pop up anywhere online. When I log in there doesn’t appear to be any messages about my account?? Help me!! It won’t let me connect at all even when I do log in.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Important Message About My Account?
Captive WiFi at the top of the screen suggests that your trying to log into a  hotspot rater than your Hub's main SSID?
If that's intentional then have a look here & see if anything helps. If you're  using the BT WiFi app, there's been suggestions that's being retired.
Message 3 of 4
I’m only clicking on the WiFi connection for my hub in the settings, no hotspot or anything like that’s just the same connection that had worked for the past month?
Message 4 of 4
Hi, did you find a solution to this issue? I’m struggling with the same thing
