Message 1 of 9
Internet does not work unless using VPN
Hi everyone,
My internet works fine on all other devices of the house, like phones and laptops, apart from my computer. Websites don't load or load partially and it seems to get stuck.  I have to hotspot or bypass BT by using a VPN so it works.
Otherwise, I keep getting messages like the one below.
Does anyone have any idea of how to fix it? I have called BT and they said that the problem is with my computer. My company support, this is a work computer, says that the problem must be BT because once I bypass it, the internet works perfectly.
Thanks for your help 🙂
8 REPLIES 8
Message 2 of 9
Re: Internet does not work unless using VPN
How on earth can it be a BT problem if every other device except your computer works?
Your company IT support appear to be clueless
Anonymous
Not applicable
Message 3 of 9
How is the PC connected to the (presumably) BT Hub?
How are the other laptops connected?
When did this start happening?
As the message says, I'd suspect a DNS configuration issue. But as this is a work PC you really don't want third parties chipping in with config changes that could wreck the ability to connect to the company servers.
As above, you need to point out to your helpdesk that this is the only machine affected & get them to sort it.
Message 4 of 9
Hi,
They are all connect via wireless to the BT hub. It started happening on Monday.
The company support says that's a problem between my computer and the hub / BT connection.
Do mind saying what's the solution so I can take it to them and they would be able to assess if it's worth it changing the configurations? I couldn't go really far since I don't have admin privileges.
Thanks 🙂
Message 5 of 9
It is their computer and they need to fix it. Not knowing the exact configuration required for it to connect to your office, nobody here is in a position to offer suggestions for any config changes.
If the problem only started recently, I would quiz your IT people about any updates/changes they might have made when it stopped working.
Message 6 of 9
Sounds like a config issue with the VPN. This is not BT's responsibility and your employers IT team so know how to rectify it.
Anonymous
Not applicable
Message 7 of 9
I'd try an ethernet connection.
You could also run ipconfig /all from a Command Prompt on both the PC & a working laptop & look for differences.
But as already said, with no knowledge of how the PC should be configured, only your helpdesk can solve this. The fact they think the problem is between the PC & the Hub, ie the air, would suggest you need to try to escalate the issue to someone who knows what they're doing.
Message 8 of 9
Presumably you're talking about a VPN supplied by your employer? Your VPN is providing a 'secure tunnel' into their systems and you are accessing the internet through their internet gateway. It will likely have a fairly 'locked down' configuration deliberately targeted at limiting internet use unless it's where they can keep an eye on it. They may therefore, have restricted internet access on the PC to 'via VPN' only - my former employer did similar.
That said, why it would suddenly change and the helpdesk don't know about it is strange. It could be that a security patch within the system has unintentionally altered your configuration. You could ask colleagues if they're having similar problems.
Message 9 of 9
@caioturbiani  While you're waiting for the office IT to offer further help, try clearing your browser's cache, cookies and history and have another go.
You might also try another browser.
