Message 11 of 11
Re: Internet keeps dropping out
Welcome to the Community, @TonyG616
I know you mentioned that the online reporting tool didn't work for you, but do you happen to know which mobile number is registered on the account?
If you send us a text with HELP to 61998, this will guide you through some troubleshooting steps, run a check on your line, then needs be advise you of some next steps.
Peter
