Message 1 of 3
Is there a way to see which device is crippling my intetnet please? (0.02mb down, 0.00mb up)
Hello, our internet runs at around 16mb down, 1mb up on a good day. The problem is if anything uses the upload it becomes completely unusable. Working from home in particular is tricky.
What I think is happening, is one of our devices is using that precious 1mb upload and it's making the entire thing unusable. If I intentionally upload (say, backing up my photos on my phone) then the same thing happens, which is what's making me think that a device is uploading without me realising.
If I login to the router and click devices it shows all of the total download and upload for each device, but not the current speeds. I also can't see a way to reset it to zero, which would also allow me to keep an eye on what's uploading.
Thank you
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Is there a way to see which device is crippling my intetnet please? (0.02mb down, 0.00mb up)
@brmbl
Have you tried switching off each of your devices, one at a time, and then doing a speed test after each one, until you isolate the culprit?
Message 3 of 3
@brmbl
Why not take readings of usage , don't actively use anything for an hour or so & then take another set of readings.
