Message 1 of 4
Issue connecting Sricam to wi fi
My Sricam info says ensure DHCP is enabled. I cannot see how to find this to ensure it is.
Every time I go through the Sricam instuction to connect I get a connection error?
Could anyone please advise
3 REPLIES 3
Message 2 of 4
Re: Issue connecting Sricam to wi fi
if using BT SH2 then DHCP is automatically enabled
as your Sricam connects to 2.4ghz wifi you may find it helps if you go to hub manager 192.168.1.254 into address bar then wifi and disable the 5ghz network and see if that helps it connect  assuming it does connect then go back and re-enable the 5ghz network for other devices
Message 3 of 4
Thanks for you reply, I keep getting 'Network Error' what would you suggest please
Message 4 of 4
when you connect the Sricam do you get option to connect to your hub SSID?  if so are you entering the wifi password from hub (unless you changed it) and trying to connect?  did you disable the 5ghz network in the hub wireless?
