Message 1 of 4
Second Router
I am currently trying to add wi-fi to my shed at the top of the garden which I am changing to a summer house.  My question is can I run an Ethernet cable from my current BT Hub 2 up to the summer house and plug only into another BT Hub 2?  Will this work and give me WiFi in the garden where it doesn't currently reach?
thanks
3 REPLIES 3
Message 2 of 4
Re: Second Router
Yes, but unless you already have a spare Hub2, you would be better off buying a wireless access point (WAP)
If the shed is on the same mains consumer unit as the existing hub, you can simply use powerline adapters.
Message 3 of 4
Re: Second Router
How does the WAP work?  Would I still need to run an Ethernet up to the shed from my existing hub?
Message 4 of 4
Re: Second Router
Yes, you are effectively considering using the second hub as a WAP so a simple WAP in the first place is an alternative if you are having to make a purchase.
However, powerline adapters obviate the need to run an Ethernet cable.
See  https://www.tp-link.com/uk/home-networking/powerline/
