Message 1 of 3
JBL Bar Studio Bricked?
Hi guys, I have the same issue as @dewanshu01 , I was doing a firmware update on my bar studio sound bar, it was supposed to take 14 mins as it stated in the documentation they sent me, but it took the whole day and when I tried to restart it, it bricked and its showing the orange light for 2-3 secs then it switches off. Can anyone please advise on a possible solution ?
2 REPLIES 2
Message 2 of 3
Re: JBL Bar Studio Bricked?
I would suggest you contact the JBL customer service as it appears a problem with their firmware update
Message 3 of 3
The same thing happened to me. I couldn't find a solution yet, and JBL's support is unable to help with the warranty over. It's annoying, because the product was defective right from the start, but I just recently figured out that it could possibly be fixed with a firmware update. I requested a firmware from JBL support, and followed their instructions, but I ended up with a bricked soundbar and a 15% coupon... thanks but no thanks, no more JBL products in my home.
