Message 1 of 5
Laptop WiFi options - which should I go for?
Hi All,
I need to buy a new laptop.  The model that I'm looking at offers three WiFi options.
1.  WiFi 6 AX
2.  11AC (2x2)
3.  WiFi 6E 2x2 AX
I have two routers:  a BTHomeHub2-9HSQ  and a BTHub6-CGFG
So my question is:  Which WIFI option should I go for, and will it be compatible with those two routers?
Thanks,
Tim
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Laptop WiFi options - which should I go for?
BT Hubs don't support WiFi6, so pointless paying a premium for it on the new laptop. You would need to add a WiFi6 WAP to see any benefit.
But even then, unless you routinely move huge files around your network or make huge downloads (& have a fast fibre connection), you'll see little real-world benefit.
Message 3 of 5
Thanks. In this case, there is no price difference, so which option would you suggest?
Anonymous
Not applicable
Message 4 of 5
Then go for the latest standard which is 6e. They should all be backwards compatible but maybe check the manufacturer's forums for any reports of issues first.
Message 5 of 5
That's great advice. Thanks!
Tim
