Message 1 of 6
MAC Address
 I'm trying to decipher what is showing on my network.  We have BT broadband.
I only have 5 unknown devices left on the network, and I have 1 smart meter, 2 Sky Q mini boxes and 2 DV handsets to allocate to the aforementioned unknown devices.
Can anyone help with the issue of MAC addresses for these?
Any help greatly received.  Thanks
5 REPLIES 5
Message 2 of 6
Re: MAC Address
Message 3 of 6
Re: MAC Address
A smart meter would not normally use your home network. Also a DV phone is Dect so once again would not show on the network.
Do you have any power line adaptors or WiFi extenders?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 6
Re: MAC Address
Hi and thanks for response. I really am IT illiterate.
I’ve checked the 5 Mac addresses that are left on the network, and results are same for all of them, true MAC address, no virtual machine, LAA (whatever that means).
I suspect that at least 3 of the Mac addresses refer to old i phones, would that be possible?  They are all off line and no date or time when last on line.
I really appreciate you taking the time to reply
Message 5 of 6
Re: MAC Address
Just factory reset your hub and see if they reappear.
Message 6 of 6
Re: MAC Address
Thank you
