Message 1 of 7
Weak WiFi?
We've movedto a house with a small conservatory at the back. The conservatory has very poor WiFi. Would it be covered by the BT WiFi guarantee or would it fail on a technicality? Ie it used to be an outside space?
6 REPLIES 6
Message 2 of 7
Re: Weak WiFi?
What WiFi guarantee?
Message 3 of 7
Re: Weak WiFi?
Message 4 of 7
Re: Weak WiFi?
Guess so though I don't really know the mechanics of it. From that link it looks as though I would need a new hub though (currently got a HH6).
Message 5 of 7
Re: Weak WiFi?
Yes, and an upgrade to your contract.
Probably cheaper to just use a powerline WiFi hotspot.
Have a look at https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220-kit/
Message 6 of 7
Re: Weak WiFi?
It would be covered.
Message 7 of 7
Re: Weak WiFi?
Thanks for the advice, think I'll go for the hotspot suggestion, don' t want to commit to a new contract.
