Message 1 of 3
Multiple issues with TPLink Power line Adapters
I recently bought a TPLink Passthrough Powerline adapter kit. Initial set up worked perfectly, however I get very slow download speeds on the PC connected through ethernet (15mbps compared to 50 on wirelessly connected devices). Additionally, the router keeps dropping it's connection every few minutes while plugged into the TPLink device (flashing orange light). It is a BT Smart Hub 2. Any recommendations?
2 REPLIES 2
Message 2 of 3
Re: Multiple issues with TPLink Power line Adapters
In my experience they just work.  I have a couple in various parts of my house connected to a SH2 and FTTP connection and have no problems.
Message 3 of 3
I could simply be poor electrical wiring in your home that is causing a problem.  are both tplink  connected direct to a wall socket not extension cable
