Message 1 of 6
Netgear knowledge base blocked by BT
This very odd.  If I try to navigate to a Netgear knowledge base article from any normal browser, the request just hangs.  Nothing is downloaded.
However, if I use the Tor browser the page loads immediately.
https://kb.netgear.com/000065127
This suggests to me that BT is blocking this website/domain.  I've only seen similar behaviour for illegal torrenting sites.
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: Netgear knowledge base blocked by BT
Not being blocked:
Message 3 of 6
I can also navigate to it so it is obviously not being blocked by BT.
Do you have any Antivirus/Malware package that could be blocking it?
Message 4 of 6
Hi @ms10
I have just tried your link on my iPad (Safari) and Windows 11 (Edge) and zero problems. It is not being blocked by BT Broadband.
Message 5 of 6
I have Bitdefender Total Security.  But ironically, it's installed as part of Netgear's Armor security package.
Message 6 of 6
Try this link and click on the first article. It should take you to the page that you posted.
Search Results: RBR850 \/ RBS850 Firmware Version 4.6.9.11 (netgear.com)
