I have just moved over to Apple phone and iPad. Both of them report my network is not secure. Say I need psa3. I have home hub 6 and that says psa2 recommended. How do I go about upgrading the router so that I can use psa3.
Many thanks in advance
Solved! Go to Solution.
I presume you mean WPA3.
No BT routers currently have WPA3, WPA2 is perfectly secure, ignore Apple's security paranoia.
You are quite correct. It was wpa3. I am beginning to show my age. Thanks for your assurance.
Much appreciated
