I had a fiddle with some permissions on one desktop, it appears to be allowing me to scan now. I will test the other tomorrow. I really cannot pin down the cause, but at least one works, I amended permissions on the printer, though nothing should have changed from when the BT Hub was installed.
Thank you all for your input.
