Message 1 of 6
New WiFi Router
Hi
Thinking of changing my current router and replacing it with TP-Link BE9300 Wifi 7 router.
Its been some time since I had a tech upgrade, so a couple of questions before I take the plunge
1) I don't want the hassle of re-inputting my wifi name and password to each device I have, if I keep the existing wifi network name and password - would my devices still connect to it?
2) I have also got the Digital Voice package from BT - will they work with my new router?
Thanks in advance
Kin
5 REPLIES 5
Message 2 of 6
Re: New WiFi Router
@k1nster wrote:
Hi
No
Thanks in advance
Kin
I assume you have full fibre as that device is only a router not a modem/router.
Message 3 of 6
Re: New WiFi Router
Hi
Thanks for the fast response, yes I have the Full fibre 500 with Halo 3 Fibre to the Premises.
So if I were to keep the Digital Voice I still need to keep the BT router - is that what you're saying?
Regards
Kin
Message 4 of 6
Re: New WiFi Router
Yes and it has to be directly connected to the ONT, you can't hang it off the TP Link
Message 5 of 6
Re: New WiFi Router
Thanks Liquorice, in that case I won't bother.
Although I have heard that BT are introducing a wifi 7 smarthub later this year? Has anyone heard anything?
Anonymous
Not applicable
Message 6 of 6
Re: New WiFi Router
Yes, but it is likely an EE product, more info here: https://www.ispreview.co.uk/index.php/2024/02/first-pictures-of-ees-new-wifi-7-uk-broadband-router-e...
