Message 1 of 6
Noise margin: 15.2 dB / 3.3 dB, is this causing my stability problem?
Help line keep telling me to reset the router, they sent me a new router, the speed is good. I say yes I know the speed is good. I keep telling you that! Then they try and sell me a better package, bla bla, or try using a wire! I'm paying for wi-fi! It's not my connection to the router. It keeps dropping out, randomly and annoyingly whenever my wife wants to do an important meeting online! I have a feeling I'm not being told the whole truth. Is it likely that the line has too much interference? What do I do?
Thank you
5 REPLIES 5
Message 2 of 6
Re: Noise margin: 15.2 dB / 3.3 dB, is this causing my stability problem?
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router  192.168.1.254 into address bar then advanced settings then technical log information .
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
There is no guarantee of wifi speeds as often problem is interference from in your home or neighbours  have you tried changing the wifi channels -  best using wifi analyser to see channels in use
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 6
@imjollywrote:
in order for the forum members to help please can you post the stats from your router  192.167.1.254 into address bar then advanced settings then technical log information .
Typo above, @imjolly  obviously meant, 192.168.1.254
then follow his instructions.
Message 4 of 6
@Carlusha
thanks  post corrected
Message 5 of 6
@imjolly  How did you manage to correct/edit the post so long after originally posting?
Message 6 of 6
@Carlusha
You can edit a post up to an hour after it has been posted.
