Hello, I made an access point out of a secondhand smart hub 2. it seems to work perfectly. The only thing that I can't get rid of is in the menu. It says not connected to broadband and it is flashing the square purple on off but I am connected to broadband. I've checked by pinging Google with no packet loss et cetera and the purple light at the top and bottom of the hub itself is pulsing which I'm not particularly bothered about but I would like to get rid of it turning the lights off hasn't made anything happen. I've done restarts turn the hub light off in the menu but nothing works. I suspect that some sort of handshake problem maybe have you any ideas how to get rid of the flashing purple light? I mean I could stick a tape over it but that's not really a cure LOL
Solved! Go to Solution.
You can't, it hasn't got a DSL input so will always flash purple. Use black gaffer tape
Thank you, I thought as much I mounted it behind a large screen TV in the living room. It only has to serve 4iPads in that room.I had contacted BT support and this foreign woman nearly had a meltdown over the fact I had two hubs which she couldn’t get her head around, I thought she was going to call the cops at one point LOL. by the way I apologise in advance to anyone if I was in the wrong category I don’t know the procedure for doing posts. In fact I wish there was a page I could read to simplify how to proceed correctly when using a forum mind you it didn’t help that my primary iPad was having a spasm of cascading key strokes at the time. I think I’ll have to totally reset it. This is what you get when you buy things secondhand off eBay ha ha thanks once again for the help.
