Message 1 of 5
Old BT Copper cable
I am doing a redecoration. Can I ripe up old BT Copper cables in the house now that I have BT Fibre? Are the BT Copper cables ever going to be used?
4 REPLIES 4
Message 2 of 5
Re: Old BT Copper cable
Anything after the master socket is yours to do with as you please.
While the master socket belongs to Openreach I doubt they will come looking for it.
Message 3 of 5
Hi @cniv2001 and welcome.
@gg30340 is correct. Any cables after the master socket can be removed.
Cheers
David
Message 4 of 5
I've got FTTP and the old copper line is still has a live charge coming thru, is that usual? Can't be used to make calls but still 'live'. Was hoping to remove it as it's now unsightly and no longer needed. The exchange has a stop sell so won't be able to be reinstated anyway. Looking to remove the master socket as there's a new ONT.
Message 5 of 5
The master socket and any external  cable connected to the back of master is property of openreach.  Up to you if you remove but in unlikely event that openreach wanted it back you would be charged cost to replace
