Message 11 of 20
Re: PPPoE timeout on both pfSense and TP-Link AX1500
Tried all the above, no success..
I've given up on the TP-Link and returned it - the issue seems further down the line than in my settings - it's impossible that something that is as simple as a lot of people said and done couldn't be achieved on a simple router.. or on pfSense.
There has to be some kind of mac address locking + caching happening on BT side - it's the only explanation I get continuous timeouts on both sides when authentication. Heck, I even connected my mac directly to the ONT and configured PPPoE as well - nothing.
Message 12 of 20
Have you powered the ONT down?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 13 of 20
Tried power it down for 30 seconds/1 minute maybe, I have also tried reseting it few times while connected to pfSense.. Tried pfSense off the whole night and then cold boot in the morning - not sure I need also to turn off the ONT for more than few seconds/minutes
Message 14 of 20
I have read about the VLAN ID - is this something to try/take into consideration? Some people say it's required, others don't..
Message 15 of 20
30 seconds is fine for the ONT. No vlan id needed. It's a real puzzler this one - especially since you can't get a direct connection from the MAC.
Message 16 of 20
VLAN id of 101 is required but this is a modem function rather than router, so is achieved by the ONT in the case of FTTP but on a combined modem/router in the case of FTTC.
There is nothing on the BT side preventing either the pfSense or TP Link from working.
Are you sure you are entering [email protected] as the username rather than [email protected]
Message 17 of 20
@licquorice you wouldn’t believe how many times I have made sure letter by letter I had the right username 😕
Message 18 of 20
Had to be asked, it's a common sub-conscious mistake.
Message 19 of 20
Another common sense suggestion - have you tried a different Ethernet cable.
Message 20 of 20
Tried quite a few..
I ended up setting up ONT -> SH2 -> pfSense -> LAN
Portforward 1-65K and DMZ pfSense id... this is far from ideal, but got me going with me home setup..
Tried today again.. just in case - same result!
