Message 1 of 20
PPPoE timeout on both pfSense and TP-Link AX1500
Hi all,
I've been struggling to get PPPoE working with my new BT FTTP connection. It works flawlessly with the SH2, but when connection the ONT to either my pfSense box or a small TP-Link router (AX1500) it seems that they simply timeout and never get a response when authenticating with the ISP.
I have tried a lot of different things that I found here in the community , including leaving pfSense off during the night and doing a cold boot in the morning. I have also done a fresh install as I moved houses and had already quite a bit of config there.
I'm using the [email protected] with BT as password (and tried fiddling with VPN, and other configs). I'm getting without any other ideas, so I need a bit of help and hopefully someone out there would be able to help.
When I moved to this house, I had an old Huawei 4 port ONT which did not work, so they replaced it with a Nokia 10G (G-010G-Q) I believe (single port). Could it be they did some type of locking?
Any ideas or help would be appreciated !
Tags (4)
19 REPLIES 19
Message 2 of 20
Re: PPPoE timeout on both pfSense and TP-Link AX1500
Nope, no locking.
If the SH2 is working there is no problem with the ONT or network build.
Seems odd that both the pfSense and TP Link aren't working though.
It has to be a config setting in those devices, what MTU size have you set?
You don't need to configure a VLAN with FTTP either, that is done by the ONT
Message 3 of 20
On The TP-Link AX1500 on the web configuration page do you have a VLAN enabled and I'm assuming you have it setup in wireless router mode and you're conecting the RJ45 cable from the ONT modem to the WAN port on the TP-Link router?
Message 4 of 20
Exactly this. If you have a VLAN enbaled on the TP-Link then switch it off
Message 5 of 20
I believe I have tried default (for pfsense is 1500) and 1470 and 1492.. any other MTU value I could try?
Message 6 of 20
I use a TP-Link Archer VR2100 with my BT FTTP and the MTU is set to the default 1480
Message 7 of 20
Should be 1492.
Make sure VLAN is set to off.
Message 8 of 20
I'm guessing the setting is IPTV/VLAN? It is off. The other assumptions are also correct.
Message 9 of 20
None of those MTU settings seem to work on either setup (pfsense and tp-link) 😞
pfsense wan configpfsense wan configpfsense PPP logspfsense PPP logsTP-LINK PPP logsTP-LINK PPP logs
(don't mind the log date on the above, I have corrected it and tested)
Message 10 of 20
What firmware is the TP-Link on?
Have you tried its quick set up wizard?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
