Message 11 of 21
Re: Please confirm my thinking
Thanks again
i have one of these in the lounge, is that what you’re referring to?:
https://ibb.co/TqMChsQ
if so- what’s the benefit?
also- do I need to invest in cat 6 cable for the ONT to Deco ( or anywhere else?)
Message 12 of 21
Cat5e will be more than adequate.
You appear to have Ethernet cabling installed back to a patch panel.
Message 13 of 21
Thanks again - it’s just for that room though
How does it work? I connect the new Deco to the batch panel and then in the lounge cat5e cable to the AP?
Message 14 of 21
It's just an Ethernet cable between 2 points with a socket at each end rather than plugs.
Message 15 of 21
It appears you have two ethernet sockets next to your Openreach ONT, and two ethernet sockets in your lounge.  On the assumption that these sockets are connected by ethernet cables, then yes, you can connect your Deco WAN port to the ONT, and then another port to one of the ethernet sockets, and then an AP in the lounge connected to the corresponding ethernet socket there will work - this should give you better connectivity than using WiFi to connect the AP to the hub.
Message 16 of 21
Ok here goes.
no identifiable WAN port on the deco- it’s just 3 Ethernet ports so will thumb it into one of them
Message 17 of 21
It has to be a WAN port, you can't just connect to a random port. If the deco has a router mode, it must have a WAN port.
Message 18 of 21
@Docca Follow the official TP Link setup video here: https://youtu.be/IiT3YGyEtR0
You will need to download the app on a tablet or phone to set it up.
Message 19 of 21
As per message 10 !!
Message 20 of 21
Awaiting a "yessss" it's all working ;D
