Message 1 of 3
Port Forwarding
Hello,
I am trying (and failing) to open port 7654 on my hub. I’ve created a rule and tried tcp, upd and tcp/upd but to no avail.
if I use a port scanner it always has the closed status - hopefully I’m doing something stupid!
2 REPLIES 2
Message 2 of 3
Re: Port Forwarding
First of all, is the application running and listening on port 7654 otherwise it will show as closed.
Secondly I would advise giving the device a static IP address outside of the DHCP range of the hub and forward the port to the address rather than the device name
Message 3 of 3
Re: Port Forwarding
Thanks - tried that but no luck, when I check any ports with an online port checker they are all closed, even if I disable the firewall…
