Message 1 of 4
Port forwarding error - in Smarthub 2
Hi,
Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->8001, internal ports: 8001, internal client: 192.168.1.168
I have a strange, new log repeatedly in my technical log of my Smarthub 2. Can anyone explain why it appears repeatedly in my log?   If it implies a new rule is added, why is it doing it repeatedly and where can I see if this rule exists?
.168 is my iMac on which there is a CCTV security system running - which has been running for years without issue. The Smarthub had also been running without showing these log entries too.
Note: Maybe unrelated but I have had a more recent issue of the 2.4GHz and 5GHz wifi disconnecting for 3 seconds periodically.. lots of "disassociate "logs and my browser shows not connected.  I can't diagnose that but it might be related to a new BT Disc installed, or excessive switching between 2.4 and 5GHZ bands.  I tried to switch off 5 GHz and that seemed to help - but then I lose the disc as that is only 5Ghz.
BT Smart Hub 2 + BT Disc on full fibre 150Meg Halo FTTP
Macs and iphones, plus alexa, YouView box, Amazon Fire TV, Apple TV+
CFP project lead.
3 REPLIES 3
Message 2 of 4
Re: Port forwarding error - in Smarthub 2
It's UPnP opening the port
Disable UPnP in the hub advanced settings
Message 3 of 4
Thanks Licquorice. that seems to have stopped the logging.
CFP project lead.
Message 4 of 4
Thanks for getting back and letting us know it's sorted @pmosb and thanks @licquorice for the fantastic advice.
Cheers
David
