Message 11 of 28
Re: Portforwarding HeatApp
Port forwarding in itself does nothing other than open a door to your network. Unless the app knows your public IP address or you utilise an IP tracking service, it won't know where to connect to.
As said previously, most of these type of apps don't require port forwarding as the systems upload to a central server which the app connects to in order to retrieve the data.
Message 12 of 28
Message 13 of 28
The company who supplied the product advised portforwarding was required.
I did post photos of the settings and the app for further info - I’d welcome any assistance !
Message 14 of 28
@Colesy1977 It looks like no image has come through on your previous post and I can't see anything in the image console. I would recommend trying to post your images again.
Alex
Message 15 of 28
I'm still not convinced port forwarding is required, however, are you sure you are forwarding the ports to the correct internal IP address of the Heatapp hub?
Have you given the Heatapp hub a static IP address or are you relying on DHCP?
Message 16 of 28
Hi,
I believe it’s a static IP
Message 17 of 28
Message 18 of 28
What address is it? There is no security implication in posting the 192.168.1.xxx address
What ports are you forwarding?
Message 19 of 28
Portforward internal and external to 6653
Message 20 of 28
IP address?
