Message 1 of 4
Prob asked before but I cant find an answer BT SH2 with google wifi
So I have my BT sh2 on 192.168.1.254 network and google wifi plugged into the lan port on 192.168.86.1 as a mesh  , can I just change my Google lan setting to use the 192.168.1.2-254 network so its all on 1 network
Would that work ?
3 REPLIES 3
Message 2 of 4
Re: Prob asked before but I cant find an answer BT SH2 with google wifi
You will need to reconfigure the Google wifi into bridge mode rather than router mode. Unless double natting is a problem or you need to access devices on the hub network from the Google network or vice versa, not sure there is any  point though.
Message 3 of 4
google wifi cannot be out in bridge mode if more than one device , yes im having probs getting to mycloud home device from tv with Plex installed.
Message 4 of 4
So I have 2 subnets one on the google and one on the BT hub , I was wanting to connect the bt and google together on one network but I cant see hoe to turn off dhcp on the google wifi and let bt handle it
