Message 71 of 75
Re: Replace BT Smart Hub 2 with netgear R7000 router
@Jake12wrote:
Read carefully: If I buy my OWN BT SH3  off EBay can I swap my SH2 with the SH3 without any router reconfiguring?/
Now you should read very carefully. I have all ready posted this.
If you can get one from ebay you can replace your SH2 with it.
Message 72 of 75
@Jake12wrote:
I'm not. You have not answered the question.
And I'm not going to, with that attitude. @gg30340  already answered it.
Message 73 of 75
Re: Meet our next generation Smart Hub 3
I have BT SH2 with FTTP with the property wired with LAN cables and I don't need those BT discs and an in contract with BT. Can I buy a £30 BT SH3 business off Ebay and swap with the SH2 (plug and play)?
Message 74 of 75
You have already asked that question and it has been answered more than once!
Message 75 of 75
There’s a very easy solution to all of this, just stop responding to this individual because they clearly are unable to fathom out or listen to the advice given.
