Message 1 of 2
Replace Smart Hub 2 - FTTX?
Hi,
Looking to replace my Smart Hub 2.0 Router for one that has website blacklisting options built in with its parental controls.
Just tried swapping it out for a spare TPLink VR400 I have kicking around, and couldnt get a connection using the bthomebroadband with BT password ppoe details, so presume the router isn't compatible (and doesnt contain website blacklisting anyway).
What kind of router or combo would I need to get to replace the smart hub 2, it says I have a FTTX connection, and currently my Smart Hub 2 connects to a modem on the wall via ethernet, and the modem appears to be connected via what I assume is a fibre connection.
I thought given this was a modem, I would be able to use any spare router i had but clearly its not quite as straight forward as that.
Any suggestions on where to start?
1 REPLY 1
Message 2 of 2
Re: Replace Smart Hub 2 - FTTX?
Did you configure the VR400 in wireless router mode to enable the WAN port rather than xDSL mode?
The connection details are bthomehub@btbroadband.com not the string you posted
