Message 21 of 24
Re: Replacement router Asus DSL-ax82u
Factory reset and followed the wizard.
Still no internet...... Connection is established tho....
So so annoying please help😩
Message 22 of 24
Is the firmware for it fully up to date?
You have tried everything else, may as well make sure it has the latest.
I just read on a forum that other people had connection problems with this router, and a firmware update fixed it for them, as strange as it may seem.
Check in its system or administration page to see if it has the latest.
DSL-AX82U|Modem Routers|ASUS United Kingdom
Message 23 of 24
I've found a solution as weird as it seems, I have set the modulation to LLC type and it works perfectly...
How ever the old router wasn't set to this doesn't make sense to me. After many hours trying each settings individually I worked it out.
Thanks for all those who helped. The factory reset lead me into this option.
Message 24 of 24
Sometimes what works for one router just does not work for another. I found this out myself after messing around with too many of them.
Some of them really do involve trial and error to get working lol.
Glad it's working now!
