Message 11 of 24
Re: Replacement router Asus DSL-ax82u
Do you know if its firmware is fully up to date or not?
What does it say on it's Administration-> System page?
Message 12 of 24
I doubt old firmware would prevent operation.
Message 13 of 24
@Yoced123
When you set up the Asus did you use the wizard or do it manually?
Message 14 of 24
Hoping you would be along @TimCurtis
Message 15 of 24
UBR without PCR
UBR with PCR
CBR
Vbr
Gfr
NRT
I have set this as per the old modem
Message 16 of 24
Manually setup
Message 17 of 24
I happened to notice the old modem/router didnt seem to be using IPv6, what leads me to be looking at this configuration page.
maybe something here isnt correct?Screenshot 2024-02-24 153813.pngScreenshot 2024-02-24 153822.pngScreenshot 2024-02-24 153830.png
Message 18 of 24
@Yoced123
Use the wizard selecting the type of service you have and then add in the extras you need like username & password and your wireless settings.
Message 19 of 24
Factory reset first to start with a clean slate.
Message 20 of 24
Before doing any of those, Make sure it has the latest firmware, yes even Asus themselves say to update the firmware first. They know their own equipment better than us:
I will be shot down for saying this, but I'm going to post it anyway:
DSL-AX82U|Modem Routers|ASUS United Kingdom
[Troubleshooting][xDSL] Why can’t my xDSL routers establish an internet connection? | Official Suppo...
Even if the firmware is not intended to fix possible DSL connection issues, there are updates to make IPV6 work more smoothly in there. Routers are one of the important things you always want up to date, for security if not anything else. Strange that this was not suggested here.
So you may as well update before you reset it 😊
