Message 1 of 3
Replacing BT Smart Hub 2
I own another VDSL modem/router and would like to use it instead of BT Smart Hub 2. Is there any setup/config I need to be aware off?
2 REPLIES 2
Message 2 of 3
Re: Replacing BT Smart Hub 2
just make sure you set username and password if needed to
[email protected]  and password to BT if needed
remember when and if moved to digital voice then you need to use the SH2
Message 3 of 3
How did it go?
I want to connect an asus ax mesh router to my BT FTTC but the SH2 does not seem to be friendly to this as there is no modem only or bridge setting. The only option it seems is to buy a modem and toss out the SH2 altogether. BT have been promising a SH3 with WiFi 6 capabilities for nearly 2 years.
Any advice would be appreciated.
