Message 1 of 5
Unable to telnet to my Cisco switch since upgrading to Fibre 1 complete wifif
I have had BT broadband for the past 5+ years and in that time I have a home networking lab using a Cisco switch to act as a layer 2 device  allowing printers and pcs to connect. That was all working fine until I upgraded to Fibre 1 complete  wifi offering. I am now unable to telnet to that switch in order to manage it, the only saving grace is that all devices work and a reachable by ICMP.
4 REPLIES 4
Message 2 of 5
Re: Unable to telnet to my Cisco switch since upgrading to Fibre 1 complete wifif
I knew I seen this somewhere but it was so long ago I had trouble finding it.
BT Home Hub and TELNET | AVForums
Message 3 of 5
Hi Les,
Many thanks for your prompt reply.
Having spoke to BT, they also concur that port 3801 is the one to try, that after a backup and a paperclip pinhole reset of the the hub.
Luck would have it, that I have a copy of Hyperterm from the heady days of Windows XP, managed to connect via telnet first time to my Cisco switch not using TCP/IP (SSH) but TCP/IP (Winsock).
Be grateful if you could pass this on to other poor souls that are in this predicament
Regards
John
Message 4 of 5
If you tell anyone I said this I'll deny it but I first used hyperterm with, wait for it, Windows 3 but that's our secret right 🤣
Hope that sorts your problem, you'll have to post back to let us know
Message 5 of 5
Hyperterm is the canines under carriage
