Message 11 of 17
Re: Router and Disc pairing
So does that mean that I need one by the existing router and then the other is hardwired in the shed 25m away
Message 12 of 17
Let's start again.
Is there an Ethernet cable going to the shed?
Does the shed have a mains socket?
If it does, is the socket on the same consumer unit as the Hub?
Message 13 of 17
Yes. I assume you are doing this because you do not have an Ethernet cable from the house to the shed?
Message 14 of 17
Ok,
I think I have cracked it….
I am installing an Ethernet cable from the BT Hub to the shed which will be about 40m long. On the end of that there will be a TP-link AC1200 Wi-Fi  Router and that should do it, hopefully….
EE gave me a 4g hub but even though they say the $G is good in this area, it is a frustrating unit and freezes up. Therefore, back it goes….
Message 15 of 17
You don't need a router in the shed, a wireless access point will suffice.
https://www.tp-link.com/uk/home-networking/access-point/tl-wa1201/
Message 16 of 17
Message 17 of 17
@Leakyrabbit wrote:
Ok,
See message 4.
