Message 1 of 3
Router replacement for Smart Hub 2
I’m about to move into a 3 bed new build, semi detached. I need a Wi-Fi network that has a guest network option, can accommodate 20+ smart devices, and preferably can accommodate smart voice. Any suggestions for routers or mesh system? (I don’t think the house is big enough to warrant a mesh system, but would consider it if it means really strong Wi-Fi strength throughout).
2 REPLIES 2
Message 2 of 3
Re: Router replacement for Smart Hub 2
if a new build then I assume you will have FTTP.  are you using BT as your broadband provider and if so are you getting Digital voice?  if you get DV then you need to use the SH2 as first connection to ONT.  there are numerous routers available  really depends on what facilities you need and price you want to pay
Message 3 of 3
Turn off SH2 wireless and add one or more Ubiquity wireless points.
