Message 1 of 4
Router
Hello .. my BT router will not work with my off grid solar system.. it will only work if I connect straight to the generator. It goes through the sequence of lights until it gets to blue then just repeats it's self.  Any ideas?
3 REPLIES 3
Message 2 of 4
Re: Router
I think you have answered your own question with your post on the other thread.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Can-solar-panels-affect-WiFi/td-p/2280214/page/...
Message 3 of 4
Re: Router
No not quite. They are talking about actuall panels.. mine is an inverter problem.. I am convinced it's to do with the sine wave generated by the inverter..
Message 4 of 4
Re: Router
Exactly, which is what you said in the other thread. Hence answering your own question. I was only referring to your post, not the whole thread.
