Message 1 of 2
SH2 & WiFi Extender 1200
Folks
a quick one I have the above devices and also a historical BT Homespot 763.
I want to replace the homespot 763 which has one end wired into rooter and other end upstairs.
can I have two WiFi extender 1200 connected wirelessly to the SH2 and will work ok?
1 REPLY 1
Message 2 of 2
Re: SH2 & WiFi Extender 1200
You probably can, but if you do they need to be far enough apart so that they don't interfere with each other. I certainly wouldn't recommend wifi extenders in the first place let alone 2 of them.
Either consider a proper mesh system or replace your hotspots with newer TP Link devices https://www.tp-link.com/uk/home-networking/powerline/
