Message 1 of 6
SMART SETUP HUB 2
Anyone know how to switch off Smart Set Hub for Hub 2 as it is missing from the main page 192.168.1.254?
5 REPLIES 5
Message 2 of 6
Re: SMART SETUP HUB 2
Hi @andreaferns120472
It should be off by default but you can check following the instructions below.
https://community.bt.com/t5/BT-Devices/Issues-post-firmware-upgrade-home-hub-2/m-p/2228252#M27010
Message 3 of 6
It is now off by default.
Message 4 of 6
I don't know as Smart Setup  is hidden on 192.168.1.254
Message 5 of 6
Because it has been removed.
Message 6 of 6
As has ben explained it is off by default because it has been disabled/removed.
If it was still there it would pop up when you tried to connect a new device. Has that happened to you?
