Message 21 of 22
Re: Setting up IPv6 on ASUS Router Connected to Smarthub 2 with BT 900 Fibre
Yes, sorry my mistake,  wasn't thinking straight. If you change the subnet mask you are just changing the size of the subnet so the LAN and WAN will still be in the same subnet.
Message 22 of 22
Thanks for reply, will see if I can get some info on how I may be able to work this out 😂😂
